Date/Time: Sun, 19 Jan 2025 23:26:26 +0000
An issue on reversal and renko charts
View Count: 770
[2018-05-17 19:20:47] |
Andrey - Posts: 8 |
Hello, please help to fix this problem (see attached picture). It only appears on reversal and renko charts. To delete data does not help. Thank you.
Private File |
[2018-05-17 19:31:42] |
When posting an image of a chart, you need to use this method here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image We also see you are using Interactive Brokers. The only solution and the only solution is to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Otherwise, there simply is no solution whatsoever because they do not provide the proper data for these types of charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
