Date/Time: Sun, 19 Jan 2025 23:13:01 +0000
Spreadsheet for Trading Question
View Count: 625
[2018-05-17 18:28:02]
User413206 - Posts: 26
I have a question for Columns O-Z.
Are those columns reserved for formulas that don't fit in either of the Buy Entry, Buy Exit, Sell Entry, Sell Exit (Buy) columns? If so, how do you check if formulas in Columns O and P are true from Column K? I couldn't find a document explaining it.
I am assuming it is something as simple as Putting the following in Column K (Buy Entry):
=AND(O3=TRUE, P3=TRUE)
Please let me know if that is correct.
Thanks.
[2018-05-17 19:10:09]
Columns O through Z can be used for additional formulas.
This will work.
