Date/Time: Sun, 19 Jan 2025 23:16:47 +0000
data package
View Count: 842
[2018-05-17 16:54:16]
Joshua Dawson - Posts: 5
Can you tell me which data package to purchase for the ES e-mini? I have looked over the recommend feeds for the sierra trading feed and do not see the symbol.
[2018-05-17 18:24:03]
Either of the Sierra Chart service packages will work:
Description of Service Packages and Pricing: Packages
If you are asking about real-time futures data, you need to read this page:
Is Historical and Real-time Futures Data Included?
The particular symbol to use depends upon which supported Service you are using for the data.
