Date/Time: Sun, 19 Jan 2025 23:17:45 +0000
Displaying StopLoss and Target P/L
View Count: 713
[2018-05-17 16:08:19] |
User215298 - Posts: 20 |
Hello team, I remember finding this in the support forum but can´t find it anymore sorry. How can you display the Loss and Gain in $ when you move an attached order? To clarify myself, I am looking for the attached order to show how much money you are gaining / losing when the StopLoss or TakeProfit it´s hit. It´s an amount that (of course) change while you are shifting the attached order up or down. thank you a lot! |
[2018-05-17 19:29:43] |
You need to enable this option: Global Trade Settings Windows: Attached Order P/L When Modifying (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
