Date/Time: Fri, 24 Jan 2025 03:39:38 +0000
Was Oanda support recently added?
View Count: 2412
[2018-05-17 10:06:45] |
User735389 - Posts: 189 |
I just noticed options for Oanda under Trade Services. Is this currently working?
[2018-05-17 10:22:11] |
No this is currently not supported and we will remove it.
[2018-05-17 10:26:46] |
I see, will it be supported sometime in the future? If so, do you have a general ETA? Timing couldn't be better. Since GAIN removed forex support, i was going to manually integrate this.
[2018-05-17 19:12:47] |
Yes it is expected to come but we are not sure when. It is being worked on gradually by another developer. We really would not put any reliance on it coming anytime soon. That would be a mistake. As soon as it comes, we would also expect there to be problems with it as usual with integration to new services.
[2018-11-20 13:27:16] |
User164231 - Posts: 278 |
Hi, Any updates on Oanda?
[2018-11-20 18:46:09] |
This is not something we are going to be adding support for ourselves. It was decided against. Another outside developer may be supporting this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-20 18:46:38
[2019-01-02 16:48:44] |
Cavalry3162 - Posts: 523 |
@SC Another outside developer may be supporting this.
what does that mean? Some 3rd party coming up with a DTC bridge? or some external coder will code it directly into SC? please shed some light onto this. thanks, Andreas |
[2019-01-02 18:37:49] |
We are declining comment. We have not heard about anything more ourselves and we would put no reliance on this.
