Date/Time: Sun, 19 Jan 2025 23:24:38 +0000
NumbersBars - Diagonal Dominant
View Count: 891
[2018-05-17 06:43:50] |
nicktrader - Posts: 730 |
The attached Pic shows the comparison between NT and SC. The option "Diagonal Dominant..." is also set in SC. Unfortunately I don't get a "green box" as soon as a diagonal page has a value of zero. Is there a way to get a green or red box for this situation too? |
NT vs SC - NBs.png / V - Attached On 2018-05-17 06:41:27 UTC - Size: 75.5 KB - 316 views |
[2018-05-17 21:52:21] |
You need to set the option Enable Diagonal Zero Bid/Ask Compares to Yes. Refer to the documentation here for this setting: https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#Input_EnableDiagonalZeroBidAskCompares Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
