Date/Time: Sun, 19 Jan 2025 23:07:35 +0000
alert
View Count: 693
[2018-05-17 04:37:09] |
JL212703 - Posts: 6 |
Hi, I'm studying SC alert, and wondering how to set if 1. a new bar appears, lets say in a 5 mins graph 2. the price touches a specific price(such as my stop loss price) Many thanks for the helps. |
[2018-05-17 18:21:38] |
1. For this you can use the Countdown Timer study and set the Input for triggering alert at a new bar to Yes. Refer to: Countdown Timer 2. For this, you could use Symbol Alerts: Alerts Manager: Symbol Alerts Or if have a stop order entered within Sierra Chart, you could use an alert for the stop order when it gets filled: Global Trade Settings Windows: Play Alert When Order Filled (Global Settings >> General Trade Settings >> Notifications) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
