Date/Time: Tue, 15 Sep 2026 03:30:29 +0000
Acsil- Difference between price format when iterating through TnS with CTS vs other feeds.
View Count: 996
| [2018-05-16 19:18:45] |
| Zosimus - Posts: 345 |
When I iterate through the TimeAndSales array with Rithmic (and other feeds) TimeSales[TSIndex].Price returns price as 2721.750000 (ES example) but when I do this with CTS TimeSales[TSIndex].Price returns price as 272175.000000. This difference messes up calculations in my studies. If this is the way it's supposed to be then I'll just create a specific rule for CTS feed. Are there other feeds that use a different price format? |
| [2018-05-16 19:33:26] |
When working with the time and sales data, you need to use code like this: s_TimeAndSales TimeAndSalesRecord = TimeSales[TSIndex];
TimeAndSalesRecord *= sc.RealTimePriceMultiplier; Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-16 19:34:04
