Date/Time: Sun, 24 Nov 2024 09:04:03 +0000
Current Price Line
View Count: 2974
[2013-10-10 12:33:14] |
Rino - Posts: 124 |
Thanks Is there a way to get the "Current Price Line" to show up in the extended session on a RTH chart? Currently you do not have that option. It will only show in extended hours on an extended hours chart. |
[2013-10-10 22:05:51] |
We are not understanding this. The Current Price Line study can be set to display across the specified number of bars. It has no association with session times at all. And how would you display a study on the extended session bars when the chart is set to regular trading hours and does not contain those bars to begin with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-11 00:04:30] |
Rino - Posts: 124 |
Sorry, I will try to clarify with 2 snapshots. Extended trading session. http://www.sierrachart.com/image.php?l=1381449157156.png We are still in extended trading session with the chart just set for retail trading hours. http://www.sierrachart.com/image.php?l=1381449858425.png |
[2013-10-16 18:59:57] |
Rino - Posts: 124 |
Still hoping for a responce. Thanks
[2013-10-16 21:32:54] |
We see what you mean. We will add a new input to the Current Price Line study to use the last trade price from the current quote data. This is what will be needed.
