Date/Time: Sun, 19 Jan 2025 23:22:00 +0000
User Question
View Count: 711
[2018-05-16 04:15:45] |
Sierra Chart - Max - Posts: 5779 |
Hi, I close my computer last friday, move from Florida to Canada for the summer, reopen my computer today, and all my saved charts are gone. I have no clue what to do. Thx Sierra Chart Support |
[2018-05-16 05:08:29] |
The first thing to do is to locate your Chartbooks. This help topic explains how to do this: http://www.sierrachart.com/index.php?page=doc/helpdetails22.html The Chartbooks should be on your system somewhere. The other question is what version of Sierra Chart are you running? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-16 05:08:37
