Date/Time: Sun, 19 Jan 2025 23:09:34 +0000
Loading chartbooks
View Count: 1053
[2018-05-16 02:43:41] |
User667714 - Posts: 2 |
I have greencharts on my desktop and would like to also have it on my laptop. I downloaded the app to my laptop and have copied some chartbooks to my laptop, however when I open a chartbook I only see a portion of the charts. I've attempted to upload a screen shot for reference.
Attachment Deleted. greenchart screen.PNG / V - Attached On 2018-05-16 02:41:03 UTC - Size: 133.93 KB - 271 views greenchart screen.PNG / V - Attached On 2018-05-16 02:41:46 UTC - Size: 133.93 KB - 237 views |
[2018-05-16 03:13:19] |
This is not totally clear for us, but you can select the charts through the CW menu and if you do not see a particular chart then go to the Window menu and use this command. http://www.sierrachart.com/index.php?page=doc/WindowMenu.html#Maximize Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-16 03:13:44
