Date/Time: Sun, 19 Jan 2025 23:08:39 +0000
Bug in version 1745 - Duplicate charts have thin bars
View Count: 623
[2018-05-16 01:45:48]
User852663 - Posts: 21
I noticed when I duplicate a chart (source is a range bar chart) the duplicated version has bars that are really thin. I was able to fix this by going to the graphic settings for the chart, enabling the option to use global settings, apply, then uncheck that and apply again. Just wanted to give a heads up. Thanks.
[2018-05-16 02:35:39]
We will check on this.
