Date/Time: Sun, 19 Jan 2025 23:10:07 +0000
Naming/Labeling Charts within a Chartbook
View Count: 1062
[2018-05-16 01:40:35] |
a Gem Tree - Posts: 60 |
I was wondering if you guys might find the extra time to allow us to label charts with specific names. This would make navigating different chartbooks very easy, as one would know exactly what chart was for what. I can see that you've made this optional for labeling Sub-Graphs. Hopefully it isn't much work to add an option for labeling different charts within a chartbook. Date Time Of Last Edit: 2018-05-16 01:41:13
[2018-05-16 02:35:02] |
This is already supported: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TitleBarName
