Date/Time: Sun, 19 Jan 2025 23:06:49 +0000
Would like two studies with different scale in the same region
View Count: 1489
[2018-05-15 16:47:28] |
User508406 - Posts: 6 |
Hi, I am trying to put two studies in the same region, and would like the volume to just stay there, while I can scale and move the depth bars. Right now the depth bars are very tight, and when i try to move the scale everything moves, and I am unable to see the volume bars. I have tried to make them independent, tried to make them custom range, nothing is working. |
Private File Private File Private File |
[2018-05-15 18:36:30] |
Refer to the documentation here: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#OverlayingStudyOnMainPriceGraph However, Interactive Scale Range and Move will change all the graphs within a Chart Region. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-15 18:54:21] |
i tried this, is there any way to make it fit better? Like in the third picture?
[2018-05-15 19:38:47] |
When you follow the instructions linked to in post #2, provide a chart image of what you see so we can have a better understanding of what you mean by "fit better". Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-15 19:39:09
[2018-05-15 20:10:48] |
The pictures I posted in post 1 are one study is set to independent, and one to automatic. The only thing that helped was custom range.
