Date/Time: Sun, 19 Jan 2025 23:16:43 +0000
Issue with initial balance indicator and autotrading
View Count: 1045
[2018-05-15 13:22:25]
User739131 - Posts: 27
Is there a know issue with the initial balance indicator that forces the autotrader to wait for bar close before entering trades? I have unchecked all signal only on bar close tabs and still the trade will not be entered until bar close. I want it to enter on a break of the IB high or IB low. Any help you can provide is greatly appreciated.
Thank you,
MJ
[2018-05-18 04:10:14]
When you observe the Initial Balance lines, do you notice they are not updating immediately and instead when the bar closes?
Date Time Of Last Edit: 2018-05-18 04:10:41
[2018-05-18 11:45:35]
Thank you for the reply. I have figured out the problem. It was something to do with the disable trading by time period in the trading system by alert condition study.
Thanks again,
MJ
