Date/Time: Sun, 19 Jan 2025 23:18:03 +0000
$INX Chart not Updating
View Count: 996
[2018-05-14 16:15:27] |
User260560 - Posts: 37 |
Hi there, i'd like to chart SPX, so I activated S&P indices exchange data, but it seems there's about 10 min delay with the data and my intraday chart doesn't update. I updated symbol setting, updated to the latest sierra chart version, restarted my computer, and still can't get $INX chart to update, while my other charts are fine as usual. Could you let me know how to get it to work? thanks!
[2018-05-14 16:51:15] |
You should be getting the realtime data now.
