Date/Time: Sun, 19 Jan 2025 23:23:13 +0000
can i build this simple drawing?
View Count: 726
[2018-05-14 15:51:33] |
User98657 - Posts: 329 |
I find myself repeatedly typing a short text phrase at various places on the chart and then drawing a rectangle around it to highlight it. Can i build/set this to a button on my control bar as a "drawing"? Another solution might be to add labels to Markers. Date Time Of Last Edit: 2018-05-14 15:54:34
[2018-05-14 16:59:51] |
It is not supported to be able to do both the Text and the Rectangle in a single button, but you can create Control Bar buttons to add Text and Drawings separately and then move them as needed. Refer to: Chart Drawing Tools: Custom Text Drawing Control Bar Buttons And: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-14 20:41:49] |
Thanks for the response. Is there any chance we might see the ability to add labels to Markers in the future? Editing my response: Using the "reverse color" option actually gives me what i need, but it might still be cool to have the ability to label Markers. Date Time Of Last Edit: 2018-05-14 20:54:12
[2018-05-14 21:16:47] |
Yes we can add support to add text labels to Marker drawings.
