Date/Time: Sun, 19 Jan 2025 23:18:03 +0000
VBP in Chart DOM problem
View Count: 882
[2018-05-14 15:37:06] |
User844383 - Posts: 40 |
I am trying to get the VBP to work correctly in the Chart DOM. I am only able to get a volume bar every five ticks no matter what chart I have up. I am assuming the problem is that the ticks per volume bar is set to 5. I can not change that to anything lower than 5. In the data/trade service window I have the intraday storage unit set to 1 tick. I am wondering if this has something to do with GAIN?? I am following 26 different contracts, but am set up for 30. http://www.sierrachart.com/image.php?Image=1526311645414.png |
UploadImage.png / V - Attached On 2018-05-14 15:29:35 UTC - Size: 31.93 KB - 270 views Attachment Deleted. |
[2018-05-14 17:46:45] |
I figured out the problem. This second picture you can see I now have the chart, trade, and window menus at the top. In the other chartbook I don't have the menu at the top. I'm assuming it is because I had the DOM attached to the chart and all both linked to a quoteboard. At any rate I got it working correctly. http://www.sierrachart.com/image.php?Image=1526319649415.png |
[2018-05-14 22:10:48] |
The reason for the problem is explained here: Volume By Price Study: Ticks Per Volume Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
