Date/Time: Sun, 19 Jan 2025 23:19:48 +0000
DOM Order tabs covering Volume Profile
View Count: 1570
[2018-05-12 00:52:43] |
User839162 - Posts: 87 |
Is there a way to get the DOM order tabs to not cover the volume profile numbers? I pay attention to these numbers and when I'm in a trade I cannot see them. The only work around I've found is if I make the DOM's really wide, but this method compromises screen real-estate. Please advise? I've attached a screenshot for clarification. |
OverVP.PNG / V - Attached On 2018-05-12 00:52:26 UTC - Size: 1.13 MB - 1198 views |
[2018-05-12 21:49:17] |
Throwing out an idea. Maybe have an option to adjust the transparency?
[2018-05-14 18:32:32] |
We do not see how we can help with this, however, refer to the following: Chart Trading and the Chart DOM: Left Aligning Order and Position Lines The problem is you have too many market data columns. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-14 18:34:08
[2018-05-15 05:15:47] |
The aligning left removes the entry orders off of the price column, so I prefer to not use that setting. What do you mean by too many market data columns? Is it possible to move the volume profile on the right side of the DOM? Maybe create an optional column that is specifically for order information? Jigsaw has this option (see attached image). Thanks! |
Jigsaw.PNG / V - Attached On 2018-05-15 05:14:57 UTC - Size: 592.68 KB - 879 views |
