Date/Time: Sun, 19 Jan 2025 19:34:11 +0000
Apply Study to All Charts in Chartbook
View Count: 1468
[2018-05-11 18:51:29] |
User14953 - Posts: 236 |
Are items B, and C do-able in SierraChart? A. Quickly Clearing All Studies from - a - Chart - "select Analysis >> Clean Chart" - Ok. B. Quickly Clearing All Studies from - all Charts in a Chartbook - ? C. Quickly Applying - an Analysis Study - - To all Charts in a Chartbook - ? Thanks _ Study Collections: Applying a Study Collection to a Chart Quickly Clearing All Studies from a Chart [Link] - [Top] To quickly and easily clear all studies from a chart select Analysis >> Clean Chart on the menu. If you want to reapply the studies you previously had on the chart, you will first need to save those studies as a Study Collection and then you can select the Study Collection name from the Analysis menu. |
[2018-05-11 21:11:10] |
Yes this can be done through linking of the Chart Studies between the charts in a Chartbook. Refer to: Working With Charts: Chart Linking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
