Date/Time: Sun, 19 Jan 2025 19:39:58 +0000
Memory full
View Count: 717
[2018-05-11 15:44:43]
User00111 - Posts: 111
It is normal that engages so much memory.
Not saved photos in the Sierra folder
imageMemory.png / V - Attached On 2018-05-11 15:44:33 UTC - Size: 89.9 KB - 253 views
[2018-05-11 17:21:56]
That amount of memory use is normal and it is from historical Intraday data.
You can delete the data files you are no longer using by following the instructions here:
Chart Data and Chart Data Files: Deleting a Chart Data File
Date Time Of Last Edit: 2018-05-11 17:22:04
