Date/Time: Mon, 20 Jan 2025 08:27:21 +0000
This is important
View Count: 1026
[2018-05-11 11:45:08] |
User472677 - Posts: 356 |
Hi, This is important. Please consider this as a valuable improvement to your fine program. Normally I do not make improvement requests because you have your own priorities. However, after though I am requesting that you consider adding the following to the quote sheet. It will save users a fair amount of time and should be simple for you. After all you do want to save users time. 1. Select mutiple rows to deleteĀ 2. Insert multiple rows 4. Drag and drop symbols. Thx |
[2018-05-11 17:26:31] |
These are not going to come. At least not anytime soon. It would be 1 to 2 years before we would even look at this. You need to make changes to symbols through the Symbols command on the Quote Board menu. This is not even remotely simple. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-11 17:34:42
[2018-05-17 21:46:16] |
The basis of our prior response is that this is something that we cannot work on anytime soon and some of this is difficult like the drag-and-drop and that will not come. We also do not want to make promises we cannot keep. Sometimes we have items which take years before we get to them. However, we will have a look at these items: 1. Select mutiple rows to delete 2. Insert multiple rows Someone else also mentioned keyboard shortcuts to move symbols up and down directly on the Quote Board. Rather than drag-and-drop we might be able to do Cut and Paste commands for a quote board line in the next week or so. That should not be a problem at all. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-17 21:47:20
[2018-05-18 02:27:26] |
Thx. What you say you can do will be a big time saver. I am looking forward to these improvements.
[2018-06-06 12:13:00] |
Hello, I am just following up for an update on the improvements in the quote sheet. Keyboard shortcuts will be great in addition to inserting or deleting multiple rows. thx |
[2018-06-06 18:35:36] |
We cannot comment on this. Allow several months.
