Date/Time: Tue, 21 Jan 2025 00:55:54 +0000
Questions on Downloading Daily RTH data
View Count: 1484
[2018-05-11 09:21:11] |
User164231 - Posts: 278 |
Hi SC support, How do I download daily and weekly Regular Trading Hour data (OHLC and bid/ask/trade/total volume)? The Download Historical Data is not available. I tried download bar data but it is missing the bid ask volume. I tried Download Data for All Historical Chart, and then specify the start date, the message I get is as attached. Please advise what I have done wrong. Thanks. |
Private File |
[2018-05-11 17:19:27] |
Refer to: Chart Session Times: Creating Daily Bars with Custom Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-12 06:12:39] |
I am seeking solution on downloading daily data of (also weekly) OHLC and types of volume. Could you please advise how the above solution would help?
Date Time Of Last Edit: 2018-05-12 06:13:26
[2018-05-12 07:04:54] |
We updated the documentation here for this: Chart Session Times: Creating Daily Bars with Custom Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-13 03:35:28] |
I am now clear that 'download' and 'export' in SC has different meaning. Pardon for the confusion, what I meant is to 'export' Daily OHLC, trades, bid and ask volumes data to excel file. 2 Questions; 1. Why is the Bid and Ask volumes data only present in the last day but not the rest of the days? 2. How can I export the data in individual cell? As it is every line of data is lumped in a single cell. Thanks. Date Time Of Last Edit: 2018-05-13 03:36:39
120518 stock QB.jpg / V - Attached On 2018-05-13 03:30:05 UTC - Size: 172.75 KB - 346 views |
[2018-05-18 03:21:28] |
1. The chart must be an Intraday data type of chart. And in the case of when using Interactive Brokers make sure the Sierra Chart Historical Data Service is being used: http://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#UsingSierraChartHistoricalData 2. This is controlled by how you are reading the data in the program. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-21 23:12:55] |
TLT - Posts: 3 |
Is it possible to export Weekly OHLC historical data? I'm seeing here that the answer is "no", but want to confirm.
[2018-07-22 00:47:08] |
Yes, set the chart bars to 1 week per bar and use this command: Edit Menu: Edit >> Export Bar Data to Text File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-22 16:54:42
[2018-07-22 16:12:11] |
TLT - Posts: 3 |
Thank you!
