Date/Time: Mon, 20 Jan 2025 08:22:54 +0000
Numbers Bars Pullback Column Text Above/Below Bar
View Count: 1692
[2018-05-11 02:22:27] |
User106180 - Posts: 88 |
I use the 'Study Subgraph as Text Above/Below Bar' study to place subgraph values from the 'Numbers Bars Calculated Values' study above/below each Numbers Bar. These values do not get placed above/below the Numbers Bar pullback column on the far right. Is it possible to allow for this? Thank you Study description links below: 1) Study Subgraph as Text Above/Below Bar - Study Subgraph As Text Above/Below Bar 2) Numbers Bars Calculated Values - https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#s300 3) Numbers Bars - https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#s328 |
[2018-05-11 04:56:42] |
Yes we should be able to add support for this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-11 04:56:53
[2018-05-11 05:02:47] |
This Input for the study will be added to the next release and will need to be set to 1: Additional Forward Columns
[2018-05-11 11:57:20] |
Thank you. Further to this, some of the subgraph values in the 'Numbers Bars Calculated Values' study aren't shown for the pullback column, whereas others are. Would it be possible to have all subgraphs appear under the pullback column? For instance, the following subgraphs ARE shown below the pullback column: 1) SG6 - Ask Volume Total 2) SG7 - Bid Volume Total 3) SG11 - Ask Volume Bid Volume Difference Percent 4) SG36 - Volume / Sec 5) SG43 - Diagonal Positive Delta Sum 6) SG44 - Diagonal Negative Delta Sum Whereas, the following subgraphs AREN'T shown below the pullback column: 7) SG10 - Cumulative Sum of Ask Volume Bid Volume Difference - Day 8) SG24 - Ask Ticks Bid Ticks Difference 9) SG25 - Cumulative Sum of Ask Ticks Bid Ticks Difference - Day Thank you once again. |
[2018-05-11 17:25:41] |
This cannot be supported.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-11 17:25:53
[2018-05-12 02:17:56] |
I can appreciate why you may not want to add SG24 and SG25 - but what about SG10 (tick difference) as it is similar to SG11, SG43, and SG44 (volume difference)? Thanks. |
[2018-05-17 22:28:37] |
We will see about this.
[2018-05-30 01:58:01] |
For the study 'Study Subgraph Above/Below Bar as Text', the 'Additional Forward Columns' setting does not appear to be working (see attached Chartbook). Not all of the values I am displaying above Numbers Bars can be displayed above the pullback column, as they aren't shown for the pullback column in the study 'Numbers Vars Calculated Values', but volume/sec is. Thanks |
Private File |
[2018-06-06 06:15:18] |
Additional Forward Columns is still not working in the latest prerelease. Also, why can't all Number Bars Calculated Values be displayed for the pullback column? |
[2018-06-06 07:13:46] |
This will be solved in the next release. We see what the problem is. Also, why can't all Number Bars Calculated Values be displayed for the pullback column? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-06 07:14:15
