Date/Time: Sun, 19 Jan 2025 19:48:54 +0000
Sierra doesn't connect t my LMAX account
View Count: 1211
[2018-05-10 16:26:29]
KAYZER - Posts: 6
Hello
I'm writing because the software doesn't connect to mty LMAX account. (LMAX is running and the LMAX software is ok.)
this morning it was ok but now I have a problem.
please find below my log
Reading Internal Order ID file. | 2018-05-10 08:53:41
Reading Trade Orders file. | 2018-05-10 08:53:41
Reading Trade Positions file. | 2018-05-10 08:53:41
Listening on UDP port 22903. | 2018-05-10 08:53:41
Software version: 1540 | 2018-05-10 08:53:41
Uses New Spreadsheets | 2018-05-10 08:53:41
Usage end date: 2019-02-12 | 2018-05-10 08:53:41
Enabled for: Advanced Features. | 2018-05-10 08:53:41
Enabled for: Sierra Chart Historical Data Service. | 2018-05-10 08:53:41
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-05-10 08:53:41
Current selected Data/Trading service: LMAX Demo Trading - DTC | 2018-05-10 08:53:41
Chart Update Interval: 500 | 2018-05-10 08:53:41
Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2018-05-10 08:53:41
2018-05-10 15:54:08 Local computer time | 2018-05-10 08:53:41
2018-05-10 07:54:08 Local computer time in UTC | 2018-05-10 08:53:41
2018-05-10 08:54:08 Local computer time in SC Time Zone | 2018-05-10 08:53:41
2018-05-10 07:54:02 Server time in UTC | 2018-05-10 08:53:41
Local computer UTC time and Server UTC time difference: 1 seconds. | 2018-05-10 08:53:41
Program path: C:\SierraChart\ | 2018-05-10 08:53:41
Data Files path: C:\SierraChart\Data\ | 2018-05-10 08:53:41
OS Version Number: 6.2 | 2018-05-10 08:53:41
Locale Setting: C | 2018-05-10 08:53:41
Checking for new symbol settings for service code lmax | 2018-05-10 08:53:41
HTTPS connection to www.sierrachart.com:443 (3) | Creating socket. Using TLS 1.2. | 2018-05-10 08:53:41
Symbol settings are up-to-date for lmax | 2018-05-10 08:54:10
LMAX Demo Trading - DTC | Connecting to the server lmaxtrade1.sierracharts.com. Port 11097 | 2018-05-10 08:54:13
DTC Client (4) | Creating socket. Using TLS 1.2. | 2018-05-10 08:54:13
HTTPS connection to www.sierrachart.com:443 (3) | Socket gracefully closed by remote side. | 2018-05-10 08:54:15
HTTPS connection to www.sierrachart.com:443 (3) | Received socket Close event | 2018-05-10 08:54:15
HTTPS connection to www.sierrachart.com:443 (3) | Initiating close of socket by core. | 2018-05-10 08:54:15
HTTPS connection to www.sierrachart.com:443 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-05-10 08:54:15
HTTPS connection to www.sierrachart.com:443 (3) | Closed. | 2018-05-10 08:54:15
DTC Client (4) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:54:35 *
DTC Client (4) | Initiating close of socket by core. | 2018-05-10 08:54:35
DTC Client (4) | Closed. | 2018-05-10 08:54:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:54:35
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:54:35
LMAX Demo Trading - DTC | Disconnected. | 2018-05-10 08:54:35
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:54:35
LMAX Demo Trading - DTC | Connecting to the server lmaxtrade1.sierracharts.com. Port 11097 | 2018-05-10 08:54:38
DTC Client (5) | Creating socket. Using TLS 1.2. | 2018-05-10 08:54:38
DTC Client (5) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:54:59 *
DTC Client (5) | Initiating close of socket by core. | 2018-05-10 08:54:59
DTC Client (5) | Closed. | 2018-05-10 08:54:59
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:54:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:54:59
LMAX Demo Trading - DTC | Disconnected. | 2018-05-10 08:54:59
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:54:59
Checking for new symbol settings for service code lmax | 2018-05-10 08:54:59
Current selected Data/Trading service: LMAX Live Trading - DTC | 2018-05-10 08:54:59
HTTPS connection to www.sierrachart.com:443 (6) | Creating socket. Using TLS 1.2. | 2018-05-10 08:54:59
Requesting symbol settings for service code lmax. Overwrite = on. | 2018-05-10 08:55:00
Symbol settings received. | 2018-05-10 08:55:00
Processed 672 symbol settings. | 2018-05-10 08:55:00
HTTPS connection to www.sierrachart.com:443 (6) | Socket gracefully closed by remote side. | 2018-05-10 08:55:05
HTTPS connection to www.sierrachart.com:443 (6) | Received socket Close event | 2018-05-10 08:55:05
HTTPS connection to www.sierrachart.com:443 (6) | Initiating close of socket by core. | 2018-05-10 08:55:05
HTTPS connection to www.sierrachart.com:443 (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-05-10 08:55:05
HTTPS connection to www.sierrachart.com:443 (6) | Closed. | 2018-05-10 08:55:05
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:55:12
DTC Client (8) | Creating socket. Using TLS 1.2. | 2018-05-10 08:55:12
DTC Client (8) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:55:33 *
DTC Client (8) | Initiating close of socket by core. | 2018-05-10 08:55:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:55:33
DTC Client (8) | Closed. | 2018-05-10 08:55:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:55:33
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:55:33
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:55:33
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:55:36
DTC Client (9) | Creating socket. Using TLS 1.2. | 2018-05-10 08:55:36
DTC Client (9) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:55:57 *
DTC Client (9) | Initiating close of socket by core. | 2018-05-10 08:55:57
DTC Client (9) | Closed. | 2018-05-10 08:55:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:55:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:55:57
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:55:57
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:55:57
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:56:00
DTC Client (10) | Creating socket. Using TLS 1.2. | 2018-05-10 08:56:00
DTC Client (10) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:56:21 *
DTC Client (10) | Initiating close of socket by core. | 2018-05-10 08:56:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:56:21
DTC Client (10) | Closed. | 2018-05-10 08:56:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:56:21
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:56:21
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:56:21
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:56:24
DTC Client (12) | Creating socket. Using TLS 1.2. | 2018-05-10 08:56:24
DTC Client (12) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:56:45 *
DTC Client (12) | Initiating close of socket by core. | 2018-05-10 08:56:45
DTC Client (12) | Closed. | 2018-05-10 08:56:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:56:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:56:45
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:56:45
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:56:45
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:56:48
DTC Client (13) | Creating socket. Using TLS 1.2. | 2018-05-10 08:56:48
DTC Client (13) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:57:09 *
DTC Client (13) | Initiating close of socket by core. | 2018-05-10 08:57:09
DTC Client (13) | Closed. | 2018-05-10 08:57:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:57:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:57:09
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:57:09
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:57:09
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:57:12
DTC Client (15) | Creating socket. Using TLS 1.2. | 2018-05-10 08:57:12
DTC Client (15) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:57:33 *
DTC Client (15) | Initiating close of socket by core. | 2018-05-10 08:57:33
DTC Client (15) | Closed. | 2018-05-10 08:57:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:57:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:57:33
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:57:33
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:57:33
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:57:36
DTC Client (16) | Creating socket. Using TLS 1.2. | 2018-05-10 08:57:36
DTC Client (16) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:57:57 *
DTC Client (16) | Initiating close of socket by core. | 2018-05-10 08:57:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:57:57
DTC Client (16) | Closed. | 2018-05-10 08:57:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:57:57
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:57:57
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:57:57
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:58:00
DTC Client (17) | Creating socket. Using TLS 1.2. | 2018-05-10 08:58:00
DTC Client (17) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:58:21 *
DTC Client (17) | Initiating close of socket by core. | 2018-05-10 08:58:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:58:21
DTC Client (17) | Closed. | 2018-05-10 08:58:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:58:21
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:58:21
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:58:21
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:58:24
DTC Client (19) | Creating socket. Using TLS 1.2. | 2018-05-10 08:58:24
DTC Client (19) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:58:45 *
DTC Client (19) | Initiating close of socket by core. | 2018-05-10 08:58:45
DTC Client (19) | Closed. | 2018-05-10 08:58:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:58:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:58:45
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:58:45
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:58:45
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:58:48
DTC Client (20) | Creating socket. Using TLS 1.2. | 2018-05-10 08:58:48
DTC Client (20) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:59:09 *
DTC Client (20) | Initiating close of socket by core. | 2018-05-10 08:59:09
DTC Client (20) | Closed. | 2018-05-10 08:59:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:59:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:59:09
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:59:09
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:59:09
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:59:12
DTC Client (22) | Creating socket. Using TLS 1.2. | 2018-05-10 08:59:12
DTC Client (22) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:59:33 *
DTC Client (22) | Initiating close of socket by core. | 2018-05-10 08:59:33
DTC Client (22) | Closed. | 2018-05-10 08:59:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:59:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:59:33
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:59:33
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:59:33
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:59:36
DTC Client (23) | Creating socket. Using TLS 1.2. | 2018-05-10 08:59:36
DTC Client (23) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:59:58 *
DTC Client (23) | Initiating close of socket by core. | 2018-05-10 08:59:58
DTC Client (23) | Closed. | 2018-05-10 08:59:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:59:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:59:58
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:59:58
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:59:58
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 09:00:01
DTC Client (24) | Creating socket. Using TLS 1.2. | 2018-05-10 09:00:01
DTC Client (24) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 09:00:22 *
DTC Client (24) | Initiating close of socket by core. | 2018-05-10 09:00:22
DTC Client (24) | Closed. | 2018-05-10 09:00:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 09:00:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 09:00:22
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 09:00:22
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 09:00:22
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 09:00:25
DTC Client (26) | Creating socket. Using TLS 1.2. | 2018-05-10 09:00:25
DTC Client (26) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 09:00:46 *
DTC Client (26) | Initiating close of socket by core. | 2018-05-10 09:00:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 09:00:46
DTC Client (26) | Closed. | 2018-05-10 09:00:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 09:00:46
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 09:00:46
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 09:00:46
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 09:00:49
DTC Client (27) | Creating socket. Using TLS 1.2. | 2018-05-10 09:00:49
DTC Client (27) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 09:01:10 *
DTC Client (27) | Initiating close of socket by core. | 2018-05-10 09:01:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 09:01:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 09:01:10
DTC Client (27) | Closed. | 2018-05-10 09:01:10
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 09:01:10
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 09:01:10
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 09:01:13
DTC Client (29) | Creating socket. Using TLS 1.2. | 2018-05-10 09:01:13
DTC Client (29) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 09:01:34 *
DTC Client (29) | Initiating close of socket by core. | 2018-05-10 09:01:34
DTC Client (29) | Closed. | 2018-05-10 09:01:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 09:01:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 09:01:34
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 09:01:34
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 09:01:34
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 09:01:37
DTC Client (30) | Creating socket. Using TLS 1.2. | 2018-05-10 09:01:37
DTC Client (30) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 09:01:58 *
DTC Client (30) | Initiating close of socket by core. | 2018-05-10 09:01:58
DTC Client (30) | Closed. | 2018-05-10 09:01:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 09:01:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 09:01:58
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 09:01:58
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 09:01:58
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 09:02:01
DTC Client (31) | Creating socket. Using TLS 1.2. | 2018-05-10 09:02:01
DTC Client (31) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 09:02:22 *
DTC Client (31) | Initiating close of socket by core. | 2018-05-10 09:02:22
DTC Client (31) | Closed. | 2018-05-10 09:02:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 09:02:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 09:02:22
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 09:02:22
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 09:02:22
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 09:02:25
DTC Client (33) | Creating socket. Using TLS 1.2. | 2018-05-10 09:02:25
DTC Client (33) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 09:02:46 *
DTC Client (33) | Initiating close of socket by core. | 2018-05-10 09:02:46
DTC Client (33) | Closed. | 2018-05-10 09:02:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 09:02:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 09:02:46
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 09:02:46
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 09:02:46
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 09:02:49
DTC Client (34) | Creating socket. Using TLS 1.2. | 2018-05-10 09:02:49
DTC Client (34) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 09:03:10 *
DTC Client (34) | Initiating close of socket by core. | 2018-05-10 09:03:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 09:03:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 09:03:10
DTC Client (34) | Closed. | 2018-05-10 09:03:10
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 09:03:10
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 09:03:10
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 09:03:13
DTC Client (36) | Creating socket. Using TLS 1.2. | 2018-05-10 09:03:13
[2018-05-10 18:32:05]
While this is not relevant to the issue, you are running an older version.
First thing we want you to do is to update Sierra Chart following these instructions here:
This is the relevant error message:
Either there is a connectivity problem somewhere outside of your computer or a firewall on your computer is blocking the connection.
