Date/Time: Fri, 02 Oct 2026 18:26:31 +0000
problem to connect LMAX account
View Count: 978
[2018-05-10 07:44:06]
KAYZER - Posts: 6
I'm writing because I have difficulties to connect my LMAX account. This morning it was ok but since 1 hour it doesn't run.
Could you help me?
please find my log below
Reading Internal Order ID file. | 2018-05-10 08:30:45
Reading Trade Orders file. | 2018-05-10 08:30:45
Reading Trade Positions file. | 2018-05-10 08:30:45
Listening on UDP port 22903. | 2018-05-10 08:30:45
Software version: 1540 | 2018-05-10 08:30:45
Uses New Spreadsheets | 2018-05-10 08:30:45
Usage end date: 2019-02-12 | 2018-05-10 08:30:45
Enabled for: Advanced Features. | 2018-05-10 08:30:45
Enabled for: Sierra Chart Historical Data Service. | 2018-05-10 08:30:45
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-05-10 08:30:45
Current selected Data/Trading service: LMAX Live Trading - DTC | 2018-05-10 08:30:45
Chart Update Interval: 500 | 2018-05-10 08:30:45
Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2018-05-10 08:30:45
2018-05-10 15:30:55 Local computer time | 2018-05-10 08:30:45
2018-05-10 07:30:55 Local computer time in UTC | 2018-05-10 08:30:45
2018-05-10 08:30:55 Local computer time in SC Time Zone | 2018-05-10 08:30:45
2018-05-10 07:30:48 Server time in UTC | 2018-05-10 08:30:45
Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-05-10 08:30:45
Program path: C:\SierraChart\ | 2018-05-10 08:30:45
Data Files path: C:\SierraChart\Data\ | 2018-05-10 08:30:45
OS Version Number: 6.2 | 2018-05-10 08:30:45
Locale Setting: C | 2018-05-10 08:30:45
Checking for new symbol settings for service code lmax | 2018-05-10 08:30:45
HTTPS connection to www.sierrachart.com:443 (3) | Creating socket. Using TLS 1.2. | 2018-05-10 08:30:45
Symbol settings are up-to-date for lmax | 2018-05-10 08:30:57
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:31:00
DTC Client (4) | Creating socket. Using TLS 1.2. | 2018-05-10 08:31:01
HTTPS connection to www.sierrachart.com:443 (3) | Socket gracefully closed by remote side. | 2018-05-10 08:31:02
HTTPS connection to www.sierrachart.com:443 (3) | Received socket Close event | 2018-05-10 08:31:02
HTTPS connection to www.sierrachart.com:443 (3) | Initiating close of socket by core. | 2018-05-10 08:31:02
HTTPS connection to www.sierrachart.com:443 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-05-10 08:31:02
HTTPS connection to www.sierrachart.com:443 (3) | Closed. | 2018-05-10 08:31:02
DTC Client (4) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:31:22 *
DTC Client (4) | Initiating close of socket by core. | 2018-05-10 08:31:22
DTC Client (4) | Closed. | 2018-05-10 08:31:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:31:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:31:22
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:31:22
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:31:22
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:31:25
DTC Client (5) | Creating socket. Using TLS 1.2. | 2018-05-10 08:31:25
DTC Client (5) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:31:46 *
DTC Client (5) | Initiating close of socket by core. | 2018-05-10 08:31:46
DTC Client (5) | Closed. | 2018-05-10 08:31:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:31:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:31:46
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:31:46
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:31:46
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:31:49
DTC Client (7) | Creating socket. Using TLS 1.2. | 2018-05-10 08:31:49
DTC Client (7) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:32:10 *
DTC Client (7) | Initiating close of socket by core. | 2018-05-10 08:32:10
DTC Client (7) | Closed. | 2018-05-10 08:32:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:32:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:32:10
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:32:10
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:32:10
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:32:13
DTC Client (8) | Creating socket. Using TLS 1.2. | 2018-05-10 08:32:13
DTC Client (8) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:32:34 *
DTC Client (8) | Initiating close of socket by core. | 2018-05-10 08:32:34
DTC Client (8) | Closed. | 2018-05-10 08:32:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:32:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:32:34
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:32:34
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:32:34
The above has been sent to support. | 2018-05-10 08:32:35 *
HTTP connection to www.sierrachart.com:80 (9) | Creating socket. | 2018-05-10 08:32:35
Sending of the message log was completed. Please read the response that was received. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2018-05-10 08:32:36
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:32:37
DTC Client (10) | Creating socket. Using TLS 1.2. | 2018-05-10 08:32:37
HTTP connection to www.sierrachart.com:80 (9) | Socket gracefully closed by remote side. | 2018-05-10 08:32:40
HTTP connection to www.sierrachart.com:80 (9) | Received socket Close event | 2018-05-10 08:32:40
HTTP connection to www.sierrachart.com:80 (9) | Initiating close of socket by core. | 2018-05-10 08:32:40
HTTP connection to www.sierrachart.com:80 (9) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-05-10 08:32:40
HTTP connection to www.sierrachart.com:80 (9) | Closed. | 2018-05-10 08:32:40
DTC Client (10) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:32:58 *
DTC Client (10) | Initiating close of socket by core. | 2018-05-10 08:32:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:32:58
DTC Client (10) | Closed. | 2018-05-10 08:32:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:32:58
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:32:58
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:32:58
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:33:01
DTC Client (12) | Creating socket. Using TLS 1.2. | 2018-05-10 08:33:01
DTC Client (12) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:33:22 *
DTC Client (12) | Initiating close of socket by core. | 2018-05-10 08:33:22
DTC Client (12) | Closed. | 2018-05-10 08:33:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:33:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:33:22
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:33:22
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:33:22
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:33:25
DTC Client (13) | Creating socket. Using TLS 1.2. | 2018-05-10 08:33:25
DTC Client (13) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:33:46 *
DTC Client (13) | Initiating close of socket by core. | 2018-05-10 08:33:46
DTC Client (13) | Closed. | 2018-05-10 08:33:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:33:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:33:46
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:33:46
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:33:46
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:33:49
DTC Client (15) | Creating socket. Using TLS 1.2. | 2018-05-10 08:33:49
DTC Client (15) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:34:10 *
DTC Client (15) | Initiating close of socket by core. | 2018-05-10 08:34:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:34:10
DTC Client (15) | Closed. | 2018-05-10 08:34:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:34:10
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:34:10
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:34:10
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:34:13
DTC Client (16) | Creating socket. Using TLS 1.2. | 2018-05-10 08:34:13
DTC Client (16) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:34:34 *
DTC Client (16) | Initiating close of socket by core. | 2018-05-10 08:34:34
DTC Client (16) | Closed. | 2018-05-10 08:34:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:34:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:34:34
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:34:34
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:34:34
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:34:37
DTC Client (17) | Creating socket. Using TLS 1.2. | 2018-05-10 08:34:37
DTC Client (17) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:34:58 *
DTC Client (17) | Initiating close of socket by core. | 2018-05-10 08:34:58
DTC Client (17) | Closed. | 2018-05-10 08:34:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:34:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:34:58
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:34:58
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:34:58
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:35:01
DTC Client (19) | Creating socket. Using TLS 1.2. | 2018-05-10 08:35:01
DTC Client (19) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:35:22 *
DTC Client (19) | Initiating close of socket by core. | 2018-05-10 08:35:22
DTC Client (19) | Closed. | 2018-05-10 08:35:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:35:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:35:22
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:35:22
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:35:22
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:35:25
DTC Client (20) | Creating socket. Using TLS 1.2. | 2018-05-10 08:35:25
File >> Disconnect selected. | 2018-05-10 08:35:32
DTC Client (20) | Initiating close of socket by core. | 2018-05-10 08:35:32
DTC Client (20) | Closed. | 2018-05-10 08:35:32
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:35:32
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:36:32
DTC Client (22) | Creating socket. Using TLS 1.2. | 2018-05-10 08:36:32
DTC Client (22) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:36:53 *
DTC Client (22) | Initiating close of socket by core. | 2018-05-10 08:36:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:36:53
DTC Client (22) | Closed. | 2018-05-10 08:36:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:36:53
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:36:53
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:36:53
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:36:56
DTC Client (24) | Creating socket. Using TLS 1.2. | 2018-05-10 08:36:56
DTC Client (24) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:37:17 *
DTC Client (24) | Initiating close of socket by core. | 2018-05-10 08:37:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:37:17
DTC Client (24) | Closed. | 2018-05-10 08:37:17
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:37:17
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:37:17
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:37:17
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:37:20
DTC Client (25) | Creating socket. Using TLS 1.2. | 2018-05-10 08:37:20
DTC Client (25) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:37:41 *
DTC Client (25) | Initiating close of socket by core. | 2018-05-10 08:37:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:37:41
DTC Client (25) | Closed. | 2018-05-10 08:37:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:37:41
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:37:41
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:37:41
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:37:44
DTC Client (26) | Creating socket. Using TLS 1.2. | 2018-05-10 08:37:44
DTC Client (26) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:38:05 *
DTC Client (26) | Initiating close of socket by core. | 2018-05-10 08:38:05
DTC Client (26) | Closed. | 2018-05-10 08:38:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:38:05
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:38:05
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:38:05
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:38:05
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:38:08
DTC Client (28) | Creating socket. Using TLS 1.2. | 2018-05-10 08:38:08
DTC Client (28) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:38:29 *
DTC Client (28) | Initiating close of socket by core. | 2018-05-10 08:38:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:38:29
DTC Client (28) | Closed. | 2018-05-10 08:38:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:38:29
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:38:29
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:38:29
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:38:32
DTC Client (29) | Creating socket. Using TLS 1.2. | 2018-05-10 08:38:32
DTC Client (29) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:38:53 *
DTC Client (29) | Initiating close of socket by core. | 2018-05-10 08:38:53
DTC Client (29) | Closed. | 2018-05-10 08:38:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:38:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:38:53
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:38:53
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:38:53
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:38:56
DTC Client (31) | Creating socket. Using TLS 1.2. | 2018-05-10 08:38:56
DTC Client (31) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:39:17 *
DTC Client (31) | Initiating close of socket by core. | 2018-05-10 08:39:17
DTC Client (31) | Closed. | 2018-05-10 08:39:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:39:17
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:39:17
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:39:17
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:39:17
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:39:20
DTC Client (32) | Creating socket. Using TLS 1.2. | 2018-05-10 08:39:20
DTC Client (32) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:39:41 *
DTC Client (32) | Initiating close of socket by core. | 2018-05-10 08:39:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:39:41
DTC Client (32) | Closed. | 2018-05-10 08:39:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:39:41
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:39:41
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:39:41
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:39:44
DTC Client (33) | Creating socket. Using TLS 1.2. | 2018-05-10 08:39:44
DTC Client (33) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2018-05-10 08:40:05 *
DTC Client (33) | Initiating close of socket by core. | 2018-05-10 08:40:05
DTC Client (33) | Closed. | 2018-05-10 08:40:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-10 08:40:05
To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-10 08:40:05
LMAX Live Trading - DTC | Disconnected. | 2018-05-10 08:40:05
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-10 08:40:05
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2018-05-10 08:40:08
DTC Client (35) | Creating socket. Using TLS 1.2. | 2018-05-10 08:40:08
[2018-05-10 08:41:00]
This is the relevant message:
Are you running any kind of firewall or other security software on your computer, other than the Windows firewall?
Date Time Of Last Edit: 2018-05-10 08:41:16
