Date/Time: Sun, 19 Jan 2025 19:46:44 +0000
All the formulas of some of my spreadsheets disappear and I'm not able to recover it
View Count: 757
[2018-05-10 06:50:25] |
User252419 - Posts: 235 |
All the formulas of some of my spreadsheets disappear in the right Sheet Number. I finally recovered them in the backup folder. But how can I stop it from happening? Thank you Date Time Of Last Edit: 2018-05-10 07:08:49
[2018-05-10 08:36:58] |
Yes there are backup files. They are located in the /Backups subfolder in the Sierra Chart installation folder. So does this issue consistently happen? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-10 08:37:35
[2018-05-10 15:53:02] |
Since some added spreadsheets and rows it is happening everyday. thank you |
[2018-05-10 18:45:31] |
Therefore, this is probably caused by the Formula Source Sheet Number Input with the Spreadsheet Study not being set correctly. Refer to: http://www.sierrachart.com/index.php?page=doc/SpreadsheetStudyInputs.html#FormulaSourceSheetNumber Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-10 18:46:37
