Date/Time: Sun, 19 Jan 2025 19:55:47 +0000
I'm not able to change drawing properties, the window doesn't appear.
View Count: 708
[2018-05-09 16:46:09]
User252419 - Posts: 235
Suddenly, I'm not able to change chart drawing properties when I select a drawing, the window doesn't appear. I've restarted SC but it doesn't work.
Thank you
Date Time Of Last Edit: 2018-05-09 16:46:25
[2018-05-09 19:10:59]
In what version does this happen with?
It might be what is described here:
http://www.sierrachart.com/index.php?page=doc/helpdetails30.html#DialogWindowsDoNotDisplay
Otherwise, update to the latest pre-release to see if that solves it:
Date Time Of Last Edit: 2018-05-09 19:11:29
