Date/Time: Sun, 19 Jan 2025 19:45:15 +0000
Can't remove the bid/ask columns and can't colour the current traded qty column background
View Count: 940
[2018-05-09 08:47:43] |
Revan - Posts: 9 |
Hello, So I am trying to remove the bid/ask depth columns that are default when one opens a DOM and they won't leave unlike the other columns, I click to move them into the left box and they just stay in the right side box of "Customize chart/Trade DOM columns" therefore still appearing on the DOM, the other columns all move as required. The other thing is the "Current traded qty column" backgrounds, I can't seem to change the background colour, I think they are just called buy/sell columns under the graphics settings, I have unchecked global setting and clicked every column setting name it the background colour doesn't change. |
[2018-05-09 20:54:22] |
The Buy and Sell columns are always displayed in the Chart/Trade DOMs. This means that either the Buy Order Column or the Bid Size / Buy Column must be present (for the Buy/Bid side). Therefore, these can only be interchanged with each other, but not removed completely. For additional information, refer to: Global Trade Settings Windows: Buy Order Column - Left/Center/Right Aligned There is no setting to change the background for the Current Traded Bid/Ask columns. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-09 22:13:26] |
Revan - Posts: 9 |
Okay that makes sense now, I will then put in this request for you to consider making them removable or at least interchangeable, personally I only use the order columns, not a huge deal but it definitely would make it more cutomizable and sleek looking, cheers.
[2018-05-09 22:53:17] |
You just need to simply add the Buy Order Column and Sell Order column and then the bid sizes and ask sizes will no longer be displayed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-09 22:53:28
