Date/Time: Sun, 19 Jan 2025 19:39:27 +0000
internet connection and SC
View Count: 778
[2018-05-09 08:04:37] |
natanibz - Posts: 136 |
Hello, I have an internet connection with a speed in download of 40 Mbps and now it's necessary about 15 minutes to open a chartbook with quite data. Do you think that with an internet connection with a speed in download of only 7 Mbps, it's necessary more than 1 hour to open the same chartbook? Are there other differences in using SC, between the two connection above (40 and 7), besides opening chartbooks and loading data? Thanks |
[2018-05-09 08:08:56] |
This is not dependent on the Internet connection. Refer to this help topic: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often A Chartbook should open typically in less than 10 seconds. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-09 08:09:17
