Date/Time: Sun, 19 Jan 2025 19:42:33 +0000
Futures eurostoxx 50
View Count: 961
[2018-05-09 07:09:52] |
User29299 - Posts: 8 |
To get the futures eurostoxx 50 quotes in real time how to do? Thank you. |
[2018-05-09 19:43:27] |
You will need to use the Sierra Chart Exchange Data Feed and enable the EUREX exchange. Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions There is an additional cost for this. The current symbol is FXM18 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-09 20:01:05
[2018-05-10 09:52:56] |
you can send me the specific instructions step by step for future eurexx50 quotes, I do not have a broker. I could not connect with the normal instructions, I messed up, I activated the trial. I do not know what to do, help. Thank you. |
[2018-05-10 13:13:56] |
I solved everything ok. Thank you.
[2018-05-10 18:35:49] |
Yes we now see you have activated the Sierra Chart Exchange Data Feed with the EUREX exchange. Let us know if you need more help.
