Date/Time: Sun, 19 Jan 2025 19:43:29 +0000
Cumulative Last Size Not Working
View Count: 1036
[2018-05-09 06:52:48]
janos bardon - Posts: 40
Hi, on the Chart DOM the Cumulative Last Size doesn't work, not displaying the accurate number, just a blank window and no idea how to fix it.
Thanks, Janos
[2018-05-09 07:20:36]
Describe what you mean by this.
Provide an image of the chart or Trade DOM, by following these instructions:
[2018-05-09 12:13:44]
http://www.sierrachart.com/image.php?Image=1525867494335.png
[2018-05-09 19:09:24]
Okay, this is just a color settings issue.
You need to check and set these four-color settings as required:
http://www.sierrachart.com/index.php?page=doc/ChartTradingCustomizingGraphics.php#ChartDOMCumulativeLastSizeTextBidTrade
These are in Graphics Settings:
http://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html
