Date/Time: Sun, 19 Jan 2025 19:43:00 +0000
Intrday data $DOWI
View Count: 913
[2018-05-09 00:30:28] |
User833132 - Posts: 4 |
I am able to get daily charts for the cashDOW industrial using CQG with AMP but no intraday charts would there be any reason for this? Symbol is $DOWI
[2018-05-09 01:25:06] |
Yes. This is an additional service. Refer to: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#AccessCashIndexMarketData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-09 01:25:13
[2018-05-09 03:09:47] |
Thank you, I am with AMP and I signed up for Dow indices at $6 per month, but I am not able to load intraday charts on the Dow Index (I'm using $DOWI). I have mentioned this to AMP and they requested me to open a support request on the Sierra platform. What do I need to do in this case please?
[2018-05-09 05:56:16] |
We have always seen a problem with receiving the cash index data from the CQG Web API and is not something we can help with unless you know what particular symbol to use. But it is not $DOWI. We make the Sierra Chart Exchange Data Feed available for 20 USD for cash indices plus exchange fees. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-09 06:28:17] |
What symbol would you suggest I use (for the Dow Industrials Cash Index)? Or if that does not work, you have the Dow Jones Indices data for %5.25 per month, is that only EOD or intraday as well please?
[2018-05-09 19:12:41] |
We will ask CQG what the proper symbol is.
[2018-05-09 20:02:47] |
According to CQG the symbol to use is going to be X.US.DJI Let us know if that works. It is not listed, just simply manually type it into the Selected Symbol box in File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-09 20:03:22
