Date/Time: Sun, 24 Nov 2024 06:25:18 +0000
Correct data on chart
View Count: 1290
[2013-10-09 17:46:58] |
trader1 - Posts: 128 |
Hi, Can you please tell me how to open the data file and correct a group of incorrect prints? Thanks. |
[2013-10-09 17:48:39] |
Refer to help topic 2 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails2.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
