Date/Time: Sun, 19 Jan 2025 19:47:55 +0000
Gap in historical chart continuous future
View Count: 606
[2018-05-08 16:17:07] |
sierrawaves - Posts: 6 |
There is a gap in ZL continuous future on the daily chart, between Feb 20 and April 23, 2018. Setup is volume based rollover with back adjustment. On other commodities charts with same setup there is no issue, except KC between 15.12.2017 and 09.02.2018. Latest ZLN18 SC data file enclosed looks good, no data gap. http://www.sierrachart.com/image.php?Image=1525796021383.png |
Private File |
[2018-05-08 18:41:32] |
You need to follow the instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
