Date/Time: Sun, 24 Nov 2024 09:08:11 +0000
SC/CTS T4
View Count: 1426
[2013-10-09 17:40:26]
salsem - Posts: 43
Hello SC Support,
Sierra Chart /The Dorman Direct platform (CTS T4)
Spoke to the programmer . You would have to write to the API to see the spreads that way, can’t be done as is.
I would like to use T4 feed dates
I'll have problems with this
I had feed TT / Velocity
the difference compared to T4?
now I want to change for T4
is possible this setting ?...
thanks in advance
[2013-10-10 01:00:31]
Here are the instructions to use CTS T4:
http://www.sierrachart.com/index.php?l=doc/CTS_T4.php
You will also need to refer to this page if you were using a Sierra Chart account from Velocity:
http://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html
What is your question about spreads specifically?
