Date/Time: Thu, 24 Sep 2026 18:10:48 +0000
[Programming Help] - Eliminating consecutive Buy/Sell Entry signals
View Count: 6109
| [2018-05-08 14:57:58] |
| User606491 - Posts: 164 |
Regarding the spreadsheet system for trading: Certain formulas trigger multiple consecutive entry signals. How do I adjust my formulas so that I'm only executing an entry (and receiving an alert) on the first signal? A formula such as =if($J$8>0,[buy formula]=0,[buy formula]) will not work because I want to execute later entries (alerts) for pyramiding purposes. One method may be =if(and($J$8>0,[buy formula]@4:@10=1),0,[buy formula]), but this isnt elegant. Do you suggest another way to receive only one entry signal |
| [2018-05-08 15:07:33] |
| Sawtooth - Posts: 4354 |
You'll need to create a persistent variable that initiates at the first signal, and releases at another condition. Here is an example: Spreadsheet Example Formulas and Usage: Buy on First Signal and Ignore Multiple Signals |
| [2018-05-08 15:49:48] |
Thank you Tom. Will try this tonight.
| [2019-02-23 16:52:17] |
| User917679 - Posts: 76 |
Spreadsheet Example Formulas and Usage: Buy on First Signal and Ignore Multiple Signals In that section, what is the plain-english logic of "=AND(P4, P3 = 0)"? I'm a bit confused over the necessity of P4 for some reason.. EDIT: nvm got it. Date Time Of Last Edit: 2019-02-24 14:46:49
| [2022-04-26 06:56:23] |
| DayTraderEsad - Posts: 121 |
Is it possible to do this in a normal alert without using spreadsheets?
| [2022-04-26 12:27:18] |
You could do it with the Spreadsheet Formula study, in its Formula field.(This study uses Alerts syntax, despite its name) Use a formula like this: =IF(persistentcondition,1,IF(releasecondition,0,ID1.SG1[-1])) where ID1 is the Spreadsheet Formula study. Date Time Of Last Edit: 2022-04-26 12:27:30
