Date/Time: Sun, 24 Nov 2024 08:54:50 +0000
Copy chart drawings
View Count: 1676
[2013-10-09 17:09:11] |
drak33 - Posts: 20 |
Hello, is it possible to copy chart drawings from multiple charts from different Chartbooks? For example: "Chartbook1:5, Chartbook2:3". But this format does not work. Is there any other format? Thanks, Dalibor |
[2013-10-09 19:25:57] |
Yes. This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#CopyChartDrawingsfromChart Make sure you have specified the Chartbook names correctly. And do not use quote marks. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-09 21:14:20] |
I donĀ“t use quote marks and the Chartbook names are correct. And in documentation it is not written. If I write to the field "Copy Chart Drawings From Chart #s" for example: Chartbook1:5, Chartbook2:3, the drawings are copied only from Chartbook1. In other words, it is not possible to copy drawings from more chartbooks together. You can try it. Is it all right? Thanks, Dalibor |
[2013-10-09 21:26:00] |
We do see a problem and we will solve this in the next release.
[2013-10-09 21:35:28] |
For now, the solution is not to use any spaces at all in the "Copy Chart Drawings From Chart #s" box.
[2013-10-10 08:01:49] |
Great, now it works (without spaces). Many thanks.
