Date/Time: Sun, 24 Nov 2024 08:30:08 +0000
Adding Values in Values Scale when using Volume indicator
View Count: 1260
[2013-10-09 15:38:05] |
37010476 - Posts: 22 |
Wondering how I would add--other than the current volume which appears to be the only value in the values scale for volume--other values, a grid. For example, 500, 1000, 1500, 2000, etc. Presently, the values scale only provides the current volume.
[2013-10-10 01:01:58] |
You need to set the Scale Increment to 500 in the Scale Settings for the Volume study. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html#ScaleWindowStudy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
