Date/Time: Mon, 28 Sep 2026 05:53:31 +0000
[Programming Help] - This formula doesn't seem to work
View Count: 1628
| [2018-05-06 19:02:03] |
| User240019 - Posts: 112 |
I'm trying to do a simeple true/false condition so that I can color the bar that meets the following condition and this doesn't seem to be working. I'm try to ask - is the bars range longer than 6ticks & is the number of trades associated with that bar equal to or more than 350. What do I need to do? |
| [2018-05-07 01:30:30] |
| Sawtooth - Posts: 4355 |
In a spreadsheet Formula Column's row 3, try this: =AND(G3>=350,(C3-D3)/$J$21>6) You can also do this with the Color Bar Based On Alert Condition study, using the Simple Alert syntax: =AND(NT>=350,(H-L)/TICKSIZE>6) |
| [2018-05-07 12:23:41] |
thank you! How can I get the code that references various studies? For instance, you show NT = Number of Trades, where is this documented? |
| [2018-05-07 13:05:29] |
Study/Chart Alerts And Scanning Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables Spreadsheet Example Formulas and Usage |
