Date/Time: Sun, 19 Jan 2025 19:49:54 +0000
Quote sheet
View Count: 913
[2018-05-06 02:54:55]
User472677 - Posts: 356
Normally I do not make improvement requests because you have your own priorities.
However, after though I am requesting that you consider adding the following to the quote sheet. It will save users a fair amount of time and should be simple for you. After all you do want to save users time.
1. Select mutiple rows to delete
2. Insert multiple rows
4. Drag and drop symbols.
Thx
[2018-05-10 00:20:29]
I hope you are able to get these done. This will save time for your users. Sc is a very good program. Thsee features are very basic and long needed.
Thx
