Date/Time: Sun, 19 Jan 2025 19:51:40 +0000
Unable to Update Sierra Chart
View Count: 893
[2018-05-06 00:08:34]
User223734 - Posts: 103
I am using 1738 version, when I select "Download Current Version" from "Help", it doesn't work ?
[2018-05-06 00:16:10]
Xfanman1 - Posts: 320
1738 IS the current version. If you want 1741 you need to select the Pre-Release.
Scott
[2018-05-06 01:39:41]
Noted.
