Date/Time: Sun, 13 Sep 2026 07:31:12 +0000
Understanding Spreadsheet Formula Examples
View Count: 2427
[2018-05-05 09:07:23]
User172040 - Posts: 70
Hi, I'm learning the spreadsheet formulas and just need to put words to the formulas in order to understand it better.
Under Multiple Exit Automated Trading Example (Spreadsheet Systems, Alerts and Automated Trading: Multiple Exit Automated Trading Example ) you display the following code:
=IF( ABS(J8) = 5, 2, IF( ABS(J8) = 3, 3, 0)). In order for me to understand this, how do I word this? Something like
IF Position Quantity (J8) = 5 contracts, then (what does the 2 represent?) AND IF Position Quantity (J8) = 3 contracts, then (what does the 3 represent), then (what does the 0 represent?)
If you give worded examples of spreadsheet formulae, can you kindly direct me in the right direction.
Date Time Of Last Edit: 2018-05-06 22:15:46
[2018-05-05 14:49:00]
Sawtooth - Posts: 4352
"If the absolute value of J8 equals 5, then 2, else if the absolute value of J8 equals 3, then 3, else 0"
This formula goes in J26, which is the Order Quantity, so the outputs of 2, 3, and 0 are the conditional order quantities.
J8 is the Position Quantity and it will be positive if in a long, or negative if in a short, so the absolute value is used to always return a positive number.
[2018-05-13 07:05:26]
The documentation has been updated in this regard.
