Date/Time: Sun, 19 Jan 2025 19:48:15 +0000
how to calculate a subgraph output over more than the actual bar
View Count: 776
[2018-05-05 08:55:42]
MD236 - Posts: 28
I want to create a study that outputs a bar histogram showing the accumulated volume of consecutive green or red bars like in the picture I attached (it's drawed by hand). How can I achieve this using ASCIL? Or is there any example around I can use?
The problem here is that this histogram (for the green bars) goes higher with each new bar but I want to draw one complete bar over the row of all green price bars.
I hope you can help
Thanks Mario
imagequestion.jpg / V - Attached On 2018-05-05 08:55:18 UTC - Size: 9.5 KB - 236 views
[2018-05-07 23:06:07]
Have a look at using the Fill Rectangle Top and Fill Rectangle Bottom Draw Styles:
http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#DrawStyle_FillRectTop
This will give you an appearance like this.
