Date/Time: Sun, 19 Jan 2025 19:51:26 +0000
How do I configure commissions
View Count: 7635
[2018-05-03 18:35:53] |
grantx - Posts: 244 |
Trading using Lmax. How do I set the formula for commissions so that I get a proper breakdown for each trade in the trade activity log? |
[2018-05-03 18:46:32] |
The commission setting does not support a formula.
[2018-05-03 18:59:32] |
Well then how do I set commissions amount per contract?
[2018-05-03 21:29:01] |
The Round Turn Commission is set through the Global Symbol Settings: https://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#SymbolSettingsControls Also refer to: Trade Activity Log: Use Commission Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-03 21:29:32
