Date/Time: Sun, 19 Jan 2025 19:52:07 +0000
KC Wheat Bloomberg Commodity Index
View Count: 1173
[2018-05-03 18:11:07]
User844383 - Posts: 40
Hi, I am wondering if you have KC Wheat and the Bloomberg Commodity Index available on your platform? I am using GAIN Futures for my data. I usually swing trade so use daily charts and historical data. I'm thinking the Bloomberg is pretty thin so you might not carry it. KC Wheat has pretty good volume so I'm wondering if I've just not found the right symbol. I've looked under KW and KE and nothing. Appreciate the help!!
Jon
[2018-05-03 18:35:11]
Yes. You can find the available futures symbols here:
https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Futures
That page just has the underlying symbols and the month code and two digit year need to be appended.
But you should use a separate instance of Sierra Chart when using the Sierra Chart Historical Data Service:
Sierra Chart Historical Data Service: Setup Instructions
Otherwise, when using Gain Capital, the charts will not have access to the necessary Symbol Settings.
Date Time Of Last Edit: 2018-05-03 18:37:27
