Date/Time: Sun, 19 Jan 2025 19:53:05 +0000
changing broker
View Count: 1165
[2018-05-02 19:59:41] |
User376746 - Posts: 63 |
Actually my forex broker is Interactive Broker. I have to replace it. Please note that I will need only forex data feed. So have I to link the new broker to Sierrachart? or forex Sierrachart data feed (i.e. FXCM) continues to feed my Sierrachart Platform (my SC account)?
[2018-05-02 21:49:45] |
You can still use the FXCM data feed if that is all you require. That is included with all service packages: Sierra Chart Real Time and Historical Forex and CFD Data Service: Setup Instructions Or you could use LMAX: LMAX Trading Service To use LMAX you would have to have a LMAX funded account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-02 21:50:37
[2018-05-04 20:58:09] |
if I have LMAX account and if I want to run LMAX forex orders by Sierrachart, can I run on Sierrachart 1 EUR.USD BUY order +1 EUR.USD SELL order in the same time? (this is called "hedging"). 2nd question: running orders by Sierrachart could add a latency? Date Time Of Last Edit: 2018-05-04 21:09:54
[2018-05-06 22:38:17] |
can I run on Sierrachart 1 EUR.USD BUY order +1 EUR.USD SELL order in the same time? (this is called "hedging"). No, this is not supported.2nd question: running orders by Sierrachart could add a latency? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-07 12:44:40] |
I'm running Sierrachart "stand alone" but there is no connection to data feed, please why? I just need FXCM forex data feed, that is available in my SC service. log file is attached here: Reading Internal Order ID file. | 2018-05-07 15:38:28 Reading Trade Orders file. | 2018-05-07 15:38:28 Reading Trade Positions file. | 2018-05-07 15:38:28 Software version: 1506 | 2018-05-07 15:38:28 Uses New Spreadsheets | 2018-05-07 15:38:28 Usage end date: 2018-05-27 | 2018-05-07 15:38:28 Enabled for: Advanced Features. | 2018-05-07 15:38:28 Enabled for: Advanced Features 2. | 2018-05-07 15:38:28 Enabled for: Sierra Chart Historical Data Service. | 2018-05-07 15:38:28 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-05-07 15:38:28 Current selected Data/Trading service: Interactive Brokers | 2018-05-07 15:38:28 Chart Update Interval: 500 | 2018-05-07 15:38:28 Time Zone: +03:00:00 (EET+02EEST+01,M3.5.0/03:00,M10.5.0/04:00) | 2018-05-07 15:38:28 2018-05-07 14:38:32 Local computer time | 2018-05-07 15:38:28 2018-05-07 12:38:32 Local computer time in UTC | 2018-05-07 15:38:28 2018-05-07 15:38:32 Local computer time in SC Time Zone | 2018-05-07 15:38:28 2018-05-07 12:38:37 Server time in UTC | 2018-05-07 15:38:28 Local computer UTC time and Server UTC time difference: 6 seconds. | 2018-05-07 15:38:28 Program path: C:\SierraChart\ | 2018-05-07 15:38:28 Data Files path: C:\SierraChart\Data\ | 2018-05-07 15:38:28 OS Version Number: 6.2 | 2018-05-07 15:38:28 Locale Setting: C | 2018-05-07 15:38:28 Checking for new symbol settings for ib | 2018-05-07 15:38:28 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 204.15.192.108. | 2018-05-07 15:38:28 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2018-05-07 15:38:28 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2018-05-07 15:38:28 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2018-05-07 15:38:33 Symbol settings are up-to-date for ib | 2018-05-07 15:38:33 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:38:37 Starting TWS auto-login thread. | 2018-05-07 15:38:37 TWS auto-login thread ending. | 2018-05-07 15:38:37 HTTPS connection to www.sierrachart.com:443 (3) | Closed. No error. | 2018-05-07 15:38:38 HTTPS connection to www.sierrachart.com:443 (3) | SSL shutdown indicates not able to send 'close notify'. | 2018-05-07 15:38:38 HTTPS connection to www.sierrachart.com:443 (3) | SSL has been shut down. | 2018-05-07 15:38:38 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2018-05-07 15:38:38 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2018-05-07 15:38:38 Socket (4) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:38:39 Socket (4) | Shutdown and closed. | 2018-05-07 15:38:39 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:38:39 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:38:39 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:38:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:38:39 Interactive Brokers | Disconnected. | 2018-05-07 15:38:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:38:39 Starting TWS auto-login thread. | 2018-05-07 15:38:42 TWS auto-login thread ending. | 2018-05-07 15:38:42 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:38:42 Socket (5) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:38:43 Socket (5) | Shutdown and closed. | 2018-05-07 15:38:43 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:38:43 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:38:43 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:38:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:38:43 Interactive Brokers | Disconnected. | 2018-05-07 15:38:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:38:43 Starting TWS auto-login thread. | 2018-05-07 15:38:46 TWS auto-login thread ending. | 2018-05-07 15:38:46 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:38:46 Socket (6) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:38:47 Socket (6) | Shutdown and closed. | 2018-05-07 15:38:47 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:38:47 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:38:47 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:38:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:38:47 Interactive Brokers | Disconnected. | 2018-05-07 15:38:47 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:38:47 Starting TWS auto-login thread. | 2018-05-07 15:38:49 TWS auto-login thread ending. | 2018-05-07 15:38:49 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:38:50 Socket (7) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:38:51 Socket (7) | Shutdown and closed. | 2018-05-07 15:38:51 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:38:51 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:38:51 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:38:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:38:51 Interactive Brokers | Disconnected. | 2018-05-07 15:38:51 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:38:51 Starting TWS auto-login thread. | 2018-05-07 15:38:53 TWS auto-login thread ending. | 2018-05-07 15:38:53 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:38:54 Socket (8) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:38:55 Socket (8) | Shutdown and closed. | 2018-05-07 15:38:55 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:38:55 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:38:55 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:38:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:38:55 Interactive Brokers | Disconnected. | 2018-05-07 15:38:55 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:38:55 Starting TWS auto-login thread. | 2018-05-07 15:38:57 TWS auto-login thread ending. | 2018-05-07 15:38:57 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:38:58 Socket (9) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:38:59 Socket (9) | Shutdown and closed. | 2018-05-07 15:38:59 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:38:59 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:38:59 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:38:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:38:59 Interactive Brokers | Disconnected. | 2018-05-07 15:38:59 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:38:59 Starting TWS auto-login thread. | 2018-05-07 15:39:01 TWS auto-login thread ending. | 2018-05-07 15:39:01 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:39:02 Socket (10) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:39:03 Socket (10) | Shutdown and closed. | 2018-05-07 15:39:03 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:39:03 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:39:03 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:39:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:39:03 Interactive Brokers | Disconnected. | 2018-05-07 15:39:03 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:39:03 Starting TWS auto-login thread. | 2018-05-07 15:39:05 TWS auto-login thread ending. | 2018-05-07 15:39:05 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:39:06 Socket (11) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:39:07 Socket (11) | Shutdown and closed. | 2018-05-07 15:39:07 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:39:07 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:39:07 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:39:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:39:07 Interactive Brokers | Disconnected. | 2018-05-07 15:39:07 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:39:07 Starting TWS auto-login thread. | 2018-05-07 15:39:09 TWS auto-login thread ending. | 2018-05-07 15:39:09 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:39:10 Socket (12) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:39:11 Socket (12) | Shutdown and closed. | 2018-05-07 15:39:11 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:39:11 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:39:11 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:39:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:39:11 Interactive Brokers | Disconnected. | 2018-05-07 15:39:11 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:39:11 Starting TWS auto-login thread. | 2018-05-07 15:39:13 TWS auto-login thread ending. | 2018-05-07 15:39:13 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:39:14 Socket (13) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:39:15 Socket (13) | Shutdown and closed. | 2018-05-07 15:39:15 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:39:15 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:39:15 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:39:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:39:15 Interactive Brokers | Disconnected. | 2018-05-07 15:39:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:39:15 Starting TWS auto-login thread. | 2018-05-07 15:39:18 TWS auto-login thread ending. | 2018-05-07 15:39:18 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:39:18 Socket (14) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:39:19 Socket (14) | Shutdown and closed. | 2018-05-07 15:39:19 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:39:19 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:39:19 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:39:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:39:19 Interactive Brokers | Disconnected. | 2018-05-07 15:39:19 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:39:19 Starting TWS auto-login thread. | 2018-05-07 15:39:22 TWS auto-login thread ending. | 2018-05-07 15:39:22 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:39:22 Socket (15) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:39:23 Socket (15) | Shutdown and closed. | 2018-05-07 15:39:23 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:39:23 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:39:23 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:39:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:39:23 Interactive Brokers | Disconnected. | 2018-05-07 15:39:23 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:39:23 Starting TWS auto-login thread. | 2018-05-07 15:39:26 TWS auto-login thread ending. | 2018-05-07 15:39:26 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:39:26 Socket (16) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:39:27 Socket (16) | Shutdown and closed. | 2018-05-07 15:39:27 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:39:27 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:39:27 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:39:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:39:27 Interactive Brokers | Disconnected. | 2018-05-07 15:39:27 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:39:27 Starting TWS auto-login thread. | 2018-05-07 15:39:30 TWS auto-login thread ending. | 2018-05-07 15:39:30 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:39:30 Socket (17) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:39:31 Socket (17) | Shutdown and closed. | 2018-05-07 15:39:31 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:39:31 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:39:31 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:39:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:39:31 Interactive Brokers | Disconnected. | 2018-05-07 15:39:31 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:39:31 Starting TWS auto-login thread. | 2018-05-07 15:39:34 TWS auto-login thread ending. | 2018-05-07 15:39:34 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:39:34 Socket (19) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:39:35 Socket (19) | Shutdown and closed. | 2018-05-07 15:39:35 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:39:35 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:39:35 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:39:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:39:35 Interactive Brokers | Disconnected. | 2018-05-07 15:39:35 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:39:35 Starting TWS auto-login thread. | 2018-05-07 15:39:38 TWS auto-login thread ending. | 2018-05-07 15:39:38 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:39:38 Socket (20) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:39:39 Socket (20) | Shutdown and closed. | 2018-05-07 15:39:39 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:39:39 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:39:39 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:39:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:39:39 Interactive Brokers | Disconnected. | 2018-05-07 15:39:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:39:39 Starting TWS auto-login thread. | 2018-05-07 15:39:42 TWS auto-login thread ending. | 2018-05-07 15:39:42 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:39:42 Socket (21) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:39:43 Socket (21) | Shutdown and closed. | 2018-05-07 15:39:43 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:39:43 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:39:43 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:39:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:39:43 Interactive Brokers | Disconnected. | 2018-05-07 15:39:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:39:43 Starting TWS auto-login thread. | 2018-05-07 15:39:46 TWS auto-login thread ending. | 2018-05-07 15:39:46 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:39:46 Socket (22) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:39:47 Socket (22) | Shutdown and closed. | 2018-05-07 15:39:47 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:39:47 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:39:47 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:39:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:39:47 Interactive Brokers | Disconnected. | 2018-05-07 15:39:47 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:39:47 Starting TWS auto-login thread. | 2018-05-07 15:39:50 TWS auto-login thread ending. | 2018-05-07 15:39:50 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:39:50 Socket (23) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:39:51 Socket (23) | Shutdown and closed. | 2018-05-07 15:39:51 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:39:51 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:39:51 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:39:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:39:51 Interactive Brokers | Disconnected. | 2018-05-07 15:39:51 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:39:51 Starting TWS auto-login thread. | 2018-05-07 15:39:54 TWS auto-login thread ending. | 2018-05-07 15:39:54 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:39:54 Socket (24) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:39:56 Socket (24) | Shutdown and closed. | 2018-05-07 15:39:56 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:39:56 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:39:56 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:39:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:39:56 Interactive Brokers | Disconnected. | 2018-05-07 15:39:56 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:39:56 Starting TWS auto-login thread. | 2018-05-07 15:39:58 TWS auto-login thread ending. | 2018-05-07 15:39:58 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:39:58 Socket (25) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:40:00 Socket (25) | Shutdown and closed. | 2018-05-07 15:40:00 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:40:00 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:40:00 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:40:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:40:00 Interactive Brokers | Disconnected. | 2018-05-07 15:40:00 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:40:00 Starting TWS auto-login thread. | 2018-05-07 15:40:02 TWS auto-login thread ending. | 2018-05-07 15:40:02 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:40:03 Socket (26) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:40:04 Socket (26) | Shutdown and closed. | 2018-05-07 15:40:04 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:40:04 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:40:04 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:40:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:40:04 Interactive Brokers | Disconnected. | 2018-05-07 15:40:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:40:04 Starting TWS auto-login thread. | 2018-05-07 15:40:06 TWS auto-login thread ending. | 2018-05-07 15:40:06 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:40:07 Socket (27) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:40:08 Socket (27) | Shutdown and closed. | 2018-05-07 15:40:08 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:40:08 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:40:08 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:40:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:40:08 Interactive Brokers | Disconnected. | 2018-05-07 15:40:08 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:40:08 Starting TWS auto-login thread. | 2018-05-07 15:40:10 TWS auto-login thread ending. | 2018-05-07 15:40:10 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:40:11 Socket (28) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:40:12 Socket (28) | Shutdown and closed. | 2018-05-07 15:40:12 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:40:12 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:40:12 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:40:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:40:12 Interactive Brokers | Disconnected. | 2018-05-07 15:40:12 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:40:12 Starting TWS auto-login thread. | 2018-05-07 15:40:14 TWS auto-login thread ending. | 2018-05-07 15:40:14 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:40:15 Socket (29) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:40:16 Socket (29) | Shutdown and closed. | 2018-05-07 15:40:16 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:40:16 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:40:16 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:40:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:40:16 Interactive Brokers | Disconnected. | 2018-05-07 15:40:16 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:40:16 Starting TWS auto-login thread. | 2018-05-07 15:40:18 TWS auto-login thread ending. | 2018-05-07 15:40:18 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:40:19 Socket (30) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:40:20 Socket (30) | Shutdown and closed. | 2018-05-07 15:40:20 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:40:20 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:40:20 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:40:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:40:20 Interactive Brokers | Disconnected. | 2018-05-07 15:40:20 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:40:20 Starting TWS auto-login thread. | 2018-05-07 15:40:22 TWS auto-login thread ending. | 2018-05-07 15:40:22 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:40:23 Socket (31) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:40:24 Socket (31) | Shutdown and closed. | 2018-05-07 15:40:24 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:40:24 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:40:24 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:40:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:40:24 Interactive Brokers | Disconnected. | 2018-05-07 15:40:24 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:40:24 Starting TWS auto-login thread. | 2018-05-07 15:40:26 TWS auto-login thread ending. | 2018-05-07 15:40:26 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:40:27 Socket (32) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:40:28 Socket (32) | Shutdown and closed. | 2018-05-07 15:40:28 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:40:28 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:40:28 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:40:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:40:28 Interactive Brokers | Disconnected. | 2018-05-07 15:40:28 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:40:28 Starting TWS auto-login thread. | 2018-05-07 15:40:30 TWS auto-login thread ending. | 2018-05-07 15:40:30 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:40:31 Socket (33) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:40:32 Socket (33) | Shutdown and closed. | 2018-05-07 15:40:32 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:40:32 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:40:32 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:40:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:40:32 Interactive Brokers | Disconnected. | 2018-05-07 15:40:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:40:32 Starting TWS auto-login thread. | 2018-05-07 15:40:34 TWS auto-login thread ending. | 2018-05-07 15:40:34 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:40:35 Socket (35) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:40:36 Socket (35) | Shutdown and closed. | 2018-05-07 15:40:36 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:40:36 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:40:36 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:40:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:40:36 Interactive Brokers | Disconnected. | 2018-05-07 15:40:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:40:36 Starting TWS auto-login thread. | 2018-05-07 15:40:38 TWS auto-login thread ending. | 2018-05-07 15:40:38 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:40:39 Socket (36) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:40:40 Socket (36) | Shutdown and closed. | 2018-05-07 15:40:40 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:40:40 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:40:40 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:40:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:40:40 Interactive Brokers | Disconnected. | 2018-05-07 15:40:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:40:40 Starting TWS auto-login thread. | 2018-05-07 15:40:42 TWS auto-login thread ending. | 2018-05-07 15:40:42 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:40:43 Socket (37) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:40:44 Socket (37) | Shutdown and closed. | 2018-05-07 15:40:44 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:40:44 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:40:44 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:40:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:40:44 Interactive Brokers | Disconnected. | 2018-05-07 15:40:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:40:44 Starting TWS auto-login thread. | 2018-05-07 15:40:46 TWS auto-login thread ending. | 2018-05-07 15:40:46 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:40:47 Socket (38) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:40:48 Socket (38) | Shutdown and closed. | 2018-05-07 15:40:48 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:40:48 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:40:48 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:40:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:40:48 Interactive Brokers | Disconnected. | 2018-05-07 15:40:48 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:40:48 Starting TWS auto-login thread. | 2018-05-07 15:40:50 TWS auto-login thread ending. | 2018-05-07 15:40:50 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:40:51 Socket (39) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:40:52 Socket (39) | Shutdown and closed. | 2018-05-07 15:40:52 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:40:52 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:40:52 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:40:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:40:52 Interactive Brokers | Disconnected. | 2018-05-07 15:40:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:40:52 Starting TWS auto-login thread. | 2018-05-07 15:40:54 TWS auto-login thread ending. | 2018-05-07 15:40:54 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:40:55 Socket (40) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:40:56 Socket (40) | Shutdown and closed. | 2018-05-07 15:40:56 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:40:56 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:40:56 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:40:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:40:56 Interactive Brokers | Disconnected. | 2018-05-07 15:40:56 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:40:56 Starting TWS auto-login thread. | 2018-05-07 15:40:58 TWS auto-login thread ending. | 2018-05-07 15:40:58 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:40:59 Socket (41) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:41:00 Socket (41) | Shutdown and closed. | 2018-05-07 15:41:00 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:41:00 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:41:00 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:41:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:41:00 Interactive Brokers | Disconnected. | 2018-05-07 15:41:00 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:41:00 Starting TWS auto-login thread. | 2018-05-07 15:41:02 TWS auto-login thread ending. | 2018-05-07 15:41:02 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:41:03 Socket (42) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:41:04 Socket (42) | Shutdown and closed. | 2018-05-07 15:41:04 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:41:04 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:41:04 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:41:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:41:04 Interactive Brokers | Disconnected. | 2018-05-07 15:41:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:41:04 Starting TWS auto-login thread. | 2018-05-07 15:41:06 TWS auto-login thread ending. | 2018-05-07 15:41:06 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:41:07 Socket (43) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:41:08 Socket (43) | Shutdown and closed. | 2018-05-07 15:41:08 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:41:08 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:41:08 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:41:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:41:08 Interactive Brokers | Disconnected. | 2018-05-07 15:41:08 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:41:08 Starting TWS auto-login thread. | 2018-05-07 15:41:10 TWS auto-login thread ending. | 2018-05-07 15:41:10 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:41:11 Socket (44) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:41:12 Socket (44) | Shutdown and closed. | 2018-05-07 15:41:12 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:41:12 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:41:12 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:41:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:41:12 Interactive Brokers | Disconnected. | 2018-05-07 15:41:12 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:41:12 Starting TWS auto-login thread. | 2018-05-07 15:41:14 TWS auto-login thread ending. | 2018-05-07 15:41:14 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:41:15 Socket (45) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:41:16 Socket (45) | Shutdown and closed. | 2018-05-07 15:41:16 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:41:16 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:41:16 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:41:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:41:16 Interactive Brokers | Disconnected. | 2018-05-07 15:41:16 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:41:16 Starting TWS auto-login thread. | 2018-05-07 15:41:18 TWS auto-login thread ending. | 2018-05-07 15:41:18 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:41:19 Socket (46) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:41:20 Socket (46) | Shutdown and closed. | 2018-05-07 15:41:20 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:41:20 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:41:20 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:41:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:41:20 Interactive Brokers | Disconnected. | 2018-05-07 15:41:20 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:41:20 Starting TWS auto-login thread. | 2018-05-07 15:41:22 TWS auto-login thread ending. | 2018-05-07 15:41:22 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:41:23 Socket (47) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:41:24 Socket (47) | Shutdown and closed. | 2018-05-07 15:41:24 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:41:24 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:41:24 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:41:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:41:24 Interactive Brokers | Disconnected. | 2018-05-07 15:41:24 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:41:24 Starting TWS auto-login thread. | 2018-05-07 15:41:26 TWS auto-login thread ending. | 2018-05-07 15:41:26 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:41:27 Socket (48) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:41:28 Socket (48) | Shutdown and closed. | 2018-05-07 15:41:28 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:41:28 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:41:28 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:41:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:41:28 Interactive Brokers | Disconnected. | 2018-05-07 15:41:28 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:41:28 Starting TWS auto-login thread. | 2018-05-07 15:41:30 TWS auto-login thread ending. | 2018-05-07 15:41:30 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:41:31 Socket (50) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:41:32 Socket (50) | Shutdown and closed. | 2018-05-07 15:41:32 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:41:32 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:41:32 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:41:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:41:32 Interactive Brokers | Disconnected. | 2018-05-07 15:41:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:41:32 Starting TWS auto-login thread. | 2018-05-07 15:41:34 TWS auto-login thread ending. | 2018-05-07 15:41:34 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:41:35 Socket (51) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:41:36 Socket (51) | Shutdown and closed. | 2018-05-07 15:41:36 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:41:36 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:41:36 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:41:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:41:36 Interactive Brokers | Disconnected. | 2018-05-07 15:41:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:41:36 Starting TWS auto-login thread. | 2018-05-07 15:41:38 TWS auto-login thread ending. | 2018-05-07 15:41:38 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:41:39 Socket (52) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:41:40 Socket (52) | Shutdown and closed. | 2018-05-07 15:41:40 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:41:40 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:41:40 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:41:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:41:40 Interactive Brokers | Disconnected. | 2018-05-07 15:41:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:41:40 Starting TWS auto-login thread. | 2018-05-07 15:41:42 TWS auto-login thread ending. | 2018-05-07 15:41:42 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:41:43 Socket (53) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:41:44 Socket (53) | Shutdown and closed. | 2018-05-07 15:41:44 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:41:44 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:41:44 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:41:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:41:44 Interactive Brokers | Disconnected. | 2018-05-07 15:41:45 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:41:45 Starting TWS auto-login thread. | 2018-05-07 15:41:46 TWS auto-login thread ending. | 2018-05-07 15:41:46 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:41:47 Socket (54) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:41:49 Socket (54) | Shutdown and closed. | 2018-05-07 15:41:49 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:41:49 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:41:49 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:41:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:41:49 Interactive Brokers | Disconnected. | 2018-05-07 15:41:49 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:41:49 Starting TWS auto-login thread. | 2018-05-07 15:41:50 TWS auto-login thread ending. | 2018-05-07 15:41:50 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:41:52 Socket (55) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:41:53 Socket (55) | Shutdown and closed. | 2018-05-07 15:41:53 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:41:53 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:41:53 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:41:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:41:53 Interactive Brokers | Disconnected. | 2018-05-07 15:41:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:41:53 Starting TWS auto-login thread. | 2018-05-07 15:41:54 TWS auto-login thread ending. | 2018-05-07 15:41:54 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-05-07 15:41:55 Socket (56) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2018-05-07 15:41:57 Socket (56) | Shutdown and closed. | 2018-05-07 15:41:57 Interactive Brokers | Failed to connect to the data and trade server. | 2018-05-07 15:41:57 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-05-07 15:41:57 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-07 15:41:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2018-05-07 15:41:57 Interactive Brokers | Disconnected. | 2018-05-07 15:41:57 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-07 15:41:57 |
[2018-05-07 18:35:15] |
You still have Sierra Chart connecting to Interactive Brokers. You need to follow the instructions here: Sierra Chart Real Time and Historical Forex and CFD Data Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
