Date/Time: Sun, 19 Jan 2025 19:53:09 +0000
Is is Possible to display indicators on trading DOM & assign orders to them
View Count: 1505
[2018-05-02 14:27:41]
User298180 - Posts: 7
Hi i was just wondering if you could help me as i am a new user to Sierra charts, I would like to know if it possible to apply a moving average / parabolic SAR indicator to the DOM and then assign entry / stop levels to them including adding an off set when i require it similar to the CQG DOM? thanks
[2018-05-02 17:51:29]
Any study can be added to a Trading DOM:
http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#AddingStudiesTradeDOM
However, you really should us be using a standard chart with studies, and use the chart trading and Chart DOM functionality. Refer to:
This really is going to make much more sense. We do not think it is wise to be looking at studies independent of chart bars because you cannot know if they are accurate and is intended.
This is supported:
http://www.sierrachart.com/index.php?page=doc/AttachedOrders.html#StudyControlledTargetsStops
Date Time Of Last Edit: 2018-05-02 17:52:20
