Date/Time: Sun, 19 Jan 2025 19:55:52 +0000
Volume Bar for Bids Asks in Buy Sell Column?
View Count: 714
[2018-05-02 13:40:24] |
User993067 - Posts: 156 |
I recall seeing an option for the DOM to have the Bid-Ask Volume graphed in the buy sell columns...similar to the draw dom graph on chart option...which is a separate column...graphics setting will not allow me to enable...option is grayed out...help is appreciated..thx
[2018-05-02 14:54:35] |
John - SC Support - Posts: 37327 |
The reason it is grayed out is because you have just the Buy Column displayed. You need to have the Bid Size/Buy Column added to the DOM and then you can select the option for Show Volume Bars. We have added some clarification on this to the documentation here: Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-02 15:18:37] |
got it thanks
