Date/Time: Sun, 19 Jan 2025 19:36:00 +0000
Problem with Study Subgraph as Text Above/Below Bar V2
View Count: 1143
[2018-05-02 12:53:51]
User184859 - Posts: 17
Replaced version 1 of this study with version 2. Now when changes are made to the chart the values disappear and I must manually recalculate the chart to get them to display. Also, it would be good if V2 had the option to draw zero values as does V1.
Unrelated to the above. Just noting that with the use of the 64 bit version we loose the Anchor VWAP tool. All the functionality of this custom study is not required. Only a means to move the starting point "on the fly" which could possibly be added to the existing VWAP study.
No reply is necessary.
Regards.
[2018-05-02 21:52:21]
This must be due to a calculation order issue. Refer to:
Chart Studies: Study Calculation Precedence And Related Issues
The study itself does work correctly.
This will be added to the next release.
This must be a custom study. It will need to be built for the 64-bit version. Refer to:
http://www.sierrachart.com/index.php?page=doc/UsingAdvancedCustomStudies.php#CustomStudyNotListedOrNotDisplayingOnChart
[2018-05-04 13:42:21]
Is it normal for a study to display all zeros when the Analysis> Studies window is opened and "OK" is pressed (even though no changes have been made to the chart)? It makes no difference where the spreadsheet study that is being referencing is located. It will continue to update the value at the current bar but not always correctly. I realize that the incorrect values are due to the calculation order issue but is there nothing that can be done about it?
Regards.
[2018-05-04 15:13:21]
We cannot answer the question in post #3 from our perspective based on the following described here:
Automated Trading Management: Troubleshooting Automated Trading System Behavior
[2018-05-04 17:34:46]
It is not an automated trading system. I can think of a number of other ways to accomplish what I want but sadly it is a Renko chart and I cannot call on the visual high and low for plotting. Anyway, I understand your time limitations, in terms of support. No reply necessary.
Regards.
[2018-05-07 02:53:02]
Yes, we fully know it is not an automated trading system but that information is still relevant in general.
